View previous topic :: View next topic |
Author |
Message |
bprzybyl member
           Posts: 615 Location: Rochester, NY
Posted: Tue Mar 15, 2011 1:19 am Post subject: |
more crappy tiny updates:
Got the OEM bushings out of the tension rods from my original donor chassis. Oddly enough, it seems one had an OEM bushing (which was leaking) and the other had a Nismo Bushing? no idea why. What was even more weird was that it was very easy to get them out (Used a hydraulic press, but still usually everything is ridiculously hard to do on this car...)
And also
Freshly painted, but I did manage to miss a few spots which sucks because you're supposed to let this paint dry 7 days before recoating. I might, then again I might not.
Tomorrow I should finish up putting bushings in the rear suspension regardless, with the exception of the swaybar ones. But they're easy. |
Back to top |
RPS13 member
            Posts: 471 Location: MN
Posted: Tue Mar 15, 2011 12:49 pm Post subject: |
bprzybyl wrote: |
lol, yup. The worst were the toe arm bushings because they have a lot of extra meat on the outside of the bushing. So not only were they a bitch to get into the shell, they didn't want to come back out the other end all the way. The RLCAs gave me trouble as well, but the chamfer on the shell of the RLCAs is really big and they were quite easy to press in.
The trick I found if they didn't come out the other side was to press the inner shells in. That always forced the poly bushing out. Another method was to put the jaws of a pair of channel locks into the end that wasn't coming out all the way and force the bushing out using leverage.
But yeah, still a royal PITA. Would you say it was worth it in the end? I'm thinking the big benefit in the end for me was that my subframe bushings were SHOT. Like I said before, I could raise the subframe roughly a half inch independent of the car when it was off the ground. I don't think my control arm bushings were THAT bad, but some of them were pretty worn when I was tearing everything apart. |
Definitely worth it, those bushings are 15-20 years old. It will handle much better. Energy suspension makes poly S14 rear subframe bushings, They dont make these for the S13 so I went with SPL aluminum subframe bushings which are nice and tight.
_________________ "Horsepower sells cars, torque wins races" - Carroll Shelby
1990 Nissan 240sx hatch - pearl white
Full Daft Innovations swap kit
2000 LS1..Tick stage 2 T56..MS3 cam..Ported 853 heads..Daft 1 3/4" longtubes..LS6 intake..Ported TB..SLP UD pulley..Katech rod bolts..BEAST!!
Back to top |
kirk member
           Posts: 953 Location: OKC
Posted: Tue Mar 15, 2011 1:52 pm Post subject: |
Working on cars can be so dumb. Hope you can get this thing back together soon!
Back to top |
2Fass240us member
            Posts: 388 Location: Charlotte, NC
Posted: Thu Mar 17, 2011 1:13 pm Post subject: |
bprzybyl wrote: |
... you're supposed to let this paint dry 7 days before recoating. |
You used an epoxy paint?
Back to top |
bprzybyl member
Posted: Thu Mar 17, 2011 1:33 pm Post subject: |
Yessir, This Stuff-
I was going to put up an update as well, but didn't have any pictures so i figured I'd wait until the next time I did. Since I've already posted... I managed to finish up the uprights! they went surprisingly quick, about an hour to press in the bushings and install the zerks in both. I'm not thrilled with the zerk location, but it'll do. WORST case I'll just have to regrease these the old fashioned way, the bushings on the other end of the arms are where the adjustment is (toe & camber). Hopefully they all work there.
And I repainted the uprights as well, 2 days after the original paint job. It does specify 7 days after the original coating (if not within an hour of first coat). But, (1) I painted fresh metal, not painted metal (I'm sure some got on painted metal, but I'm not super worried about poor appearance) and (2) they're located inside the wheel pretty much out of sight. As long as the paint slows down rust, I'm satisfied. The arms are what I wanted to make sure had no rust as they're all thin metal and I'd prefer to not rust through a suspension arm.
kirk wrote: |
Working on cars can be so dumb. Hope you can get this thing back together soon! |
Couldn't agree more on both counts.
Back to top |
bprzybyl member
Back to top |
NoClassic member
             Posts: 1967 Location: Texas
Posted: Fri Mar 18, 2011 7:44 pm Post subject: |
You may want to shave down the tension rod bushings. They have a habit of binding in their mounts at full width.
Back to top |
bprzybyl member
Posted: Sun Mar 20, 2011 12:59 am Post subject: |
Was thinking about doing that. With the other bushings I've installed, the metal sleeve has been very close to the poly bushing width wise. I noticed when assembling the tension rod bushings that they have roughly 2mm of extra poly on each side.
Only Bushings left to replace are rear diff bushings, subframe bushings (really just waiting on getting the subframe painted), swaybar bushings, and FLCA bushings. After that, there will be no rubber bushings on the car. Motor mounts are already prothanes. Oh no, I do have rubber radiator bushings....
Been doing some research to help grow cohones for doing the ring and pinion swap. The hard part seems to be setting the pinion height, and this is where I'd like some opinions if anyone has any. The first link below says when installing a new ring gear, to take the old ring and pinion and measure the height of the pinion gear and washer behind it, then make the new pinion gear and washer match that. Anyone heard this before and have any opinions? Some insight would be much appreciated as it makes sense to me that this method would work.
http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech009.htm (lol...angelfire)
http://www.differentials.com/install.html
http://www.nicoclub.com/FSM/Q45/1994_Q45/pd.pdf
http://www.pirate4x4.com/tech/billavista/PDFs/Yukon%20Gear%20Ring%20and%20Pinion%20installation%20instructions.pdf
http://www.superstallions.com/tech/drive/gears/gears.html
http://www.richmondgear.com/01instructions.html
http://www.pirate4x4.com/tech/billavista/Gear_Setup/ AMAZING LINK, REALLY COVERS A LOT
(Kinda just using this thread to put a bunch of links for setting up a rear end. LOTS of good info there on the subject)
EDIT: http://www.ka-t.org/forums/viewtopic.php?t=8863&postdays=0&postorder=asc&start=70 That guy does it. BALLURRRRRR
Back to top |
2Fass240us member
Posted: Sun Mar 20, 2011 8:21 pm Post subject: |
bprzybyl wrote: |
Yessir, This Stuff-
I've used Rustoleum Appliance Epoxy with great results. Held up very well on my S13's brake booster, which sat right next to the OE SR exhaust manifold.
Back to top |
bprzybyl member
Posted: Mon Mar 28, 2011 2:52 pm Post subject: |
^^ We used some on an oven in the house, has held up really well.
So another boring (yet interesting!) update. Managed to get the gas tank back in with minimal effort, besides lifting what seemed to be 50 lbs worth of tank and gas back up into the car with one hand.
Also removed the inside metal part of the subframe bushing that had rusted onto the stud. After quite a bit of faffing (thanks FlikstRR) and some angle grinder action it came off.
Also got the gas line completely mounted up with adel style clamps. I just noticed that I wrote about all those things in the reverse order I did them in order to reduce the chance of mixing sparks and gas.
BUT THE FUN PART! I managed to get some grit in my eye, which I promptly rubbed to get out. I thought I did, but in actuality I managed to grind a little piece into the lens of my eye (sweet!). Did that saturday night, went to "Immediate Care" on sunday, only to get a q-tip shoved in my eye and the lady to say "Yeah it looks like I got it all out". I went to the car and noticed there was still shit in there. So I went to the eye doctor today, and he took care of it. What sucks (besides the fact I don't have gory pics like everyone else when they cut themselves on saws & fan blades & such) is that I didn't get crap in my eye when angle grinding or anything exciting, it was when I was just sliding around under the car. I was wearing goggles while grinding.
Back to top |
robmc11 member
Posted: Mon Mar 28, 2011 9:11 pm Post subject: |
hahah ya i know that suffering well! all that dust,dirt and grit will always manage to get you right in the eye ball!
oh and goodjob with your gas tank, s14/15 gas tanks are mother loving frustrating to work on..
Back to top |
RPS13 member
Back to top |
bprzybyl member
Posted: Thu Mar 31, 2011 3:33 pm Post subject: |
lol, stupid eyes getting stuff in them while we're trying to get stuff done.
Been doing a lot of thinking about the diff swap, and I'm about to do it. If anyone knows about this stuff or read the links, there are 4 things that need to be set...Pinion height, pinion preload, diff preload, and ring height. My thought is I'll be able to maintain pinion preload by using the same spacer and bearings on the original pinion. the diff preload will be maintained by using the same bearings and shims from the original diff(and original VLSD for now). Ring height will be adjusted with nissan shims if needed.
That leaves the pinion height, which seems to need a spacer not available from nissan. doing some research, I should be able to use a bunch of spacers from mcmaster-carr in order to make the pinion height I'll need.
Other than that, minimal progress. Working on getting the empty subframe back in with the ES bushings so I can finally start putting suspension parts back on. then I can move on to the trans crossmember.
Back to top |
bprzybyl member
Back to top |
devlmaycry member
           Posts: 412 Location: KY
Posted: Mon Apr 04, 2011 1:24 pm Post subject: |
After I get mine up and running I would like to refurb my rear subframe like yours. I'm tired of my rusty spindles and subframe looking ugly.
Back to top |
