View previous topic :: View next topic |
Author |
Message |
LS13.5 Lv2 Member
Posted: Tue Mar 02, 2010 12:03 pm Post subject: |
Been reading a lot, not posting much.
Think this is my first one haha.
But I was wondering why EVERYONE seems to be doing the wheel tubs in the front, what is that for?
Back to top |
heiyuu member
Back to top |
bprzybyl member
           Posts: 615 Location: Rochester, NY
Posted: Sat Mar 06, 2010 6:11 pm Post subject: |
to make a long story short...
that's mine. it's in my garage. the old one is gone. more to come on that tomorrow or whenever I get a chance to upload pics and make a post. I'm not exactly happy with what had to happen, but I am very happy with the new shell (so far).
New strategy...get the motor in and running as soon as possible, then worry about upgrading suspension components and such. This would leave the following to-dos:
-Install Walbro 255 pump (still need to purchase, probably thru frsport.com)
-vette fuel filter & fittings(need all of it)
-figure out a trans cooling system, need to buy everything but the transmission.
-sort out cooling lines, current radiator is set up for an SR
-Steam Vent hose (I want to get the LS6 Crossover and tap into the top of the water pump)
-ALL the electrical
-driveshaft (see if I can get an old f-body one and modify locally)
-intake (probably thru intakehoeses.com)
-battery
-need a steering wheel
Still looking for wheels, and I really wanted to get a set of the Cobra R wheels for mustangs...but now that I've seen pictures of this car with 18's (the mustangs are 17's) I think I may have fallen in love. They really fill out the wheel wells. |
Back to top |
bprzybyl member
Posted: Thu Mar 18, 2010 7:30 pm Post subject: |
Wow, I'm horrible at updating. Been getting some work done, hopefully a good chunk tomorrow and maybe have the engine in by Sunday. Regardless, I ordered a bunch of stuff, and JEGS has become my best friend. I ordered a heap of stuff (3 items not in stock, but not essential at this point) at 2:45PM on Tuesday...received all the in stock items on Wednesday . So, I'll be doing a lot more business with JEGS from now on. Here's what I picked up and some other older items:
Fuel System
-20ft JEGS -6AN braided hose
-10 Hangers for hose
-(2) straight -6AN fittings
-(NOT PICTURED, BACKORDERED) 3/8 Push on to -6AN (Vette FPR to fuel line)
-LS1 Fuel Rail to -6AN
-LS1 Fuel injector connectors MSD-2400 (to convert truck harness for LS1 injectors)
Power Steering System
-(2) -6AN 90* Power Steering Hose Fittings
-3ft -6AN braided hose
-16x1.5mm to -6AN Fitting (P/S Pump to Line)
-14x1.5mm to -6AN Fitting (Rack High Side to Line)
-Derale Power Steering Cooler
Transmission Cooling
-B&M 70264 Transmission SuperCooler
-10ft -6AN Braided Hose
-(2) 90* Braided Hose Fittings
-(2) Straight Hose Fittings
-Pure Choice Motorsports P/N 12055 (4L60E to -6AN)
-Lokar Firewall Mount 4L60E dipstick
-(NOT PICTURED, BACKORDERED) 4L60E Cast Aluminum Pan, Stock depth
Intake System
-4" 90* Spectre Elbow
-4" Spectre Coupler
-K&N 4" Filter
-(NOT PICTURED, BACKORDERED) 4" x 24" Tube
Back to top |
jmauld member
Posted: Thu Mar 18, 2010 7:39 pm Post subject: |
You can fit 285/30/18's under the front of a S14, with nothing but a fender roll. Are you planning on going wider?
Back to top |
bprzybyl member
Posted: Thu Mar 18, 2010 7:40 pm Post subject: |
Figured I'd also throw up a couple pics of the new shell:
18" G35 7-Spoke wheels are HOPEFULLY on the way, they're paid for at least.
And here's the interior as of now:
One thing I noticed last time is that with all the work to the tranny tunnel, there was a good possibility the little linkage under the blower would get blocked or jammed, so I decided this time around to just rip out everything above the tunnel, cut the carpet and firewall insulation, and monitor how much it gets moved up and test with the blower every once and a while. After this is done, I wanna put the dash on and not rip the interior apart anymore.
With this short schedule on getting things done my goals are pretty simple, get the motor in as soon as possible while taking care of anything that can't be taken care of with the motor in. So I'm hoping to finish cleaning out and preparing the bay and then I'd like to spray it with a fresh coat of white paint to hide the repaired surface rust. There is 1 spot of rot, and I haven't fully decided how to address it yet. It's of course on of the shock towers at the corner, but multitudes better than what I was dealing with last time. So I'll probably just cut a new piece of metal, weld in, and grind it down so it looks like nothing ever happened.
Once that stuff's done and the tranny tunnel has been addressed, I want to get all the wiring on the engine and tranny, and attach the headers and crossmember. Then the plan is to lift the car enough to install the engine from under the car. We'll see how that goes...
Back to top |
bprzybyl member
Posted: Thu Mar 18, 2010 7:44 pm Post subject: |
I really liked the fit (and the look) of the Nismo LMGT4's the previous owner had on there, and they were 18 something. The new wheels are 18x8 +30 front and 18x8 +33 rear, and I'm planning on running a 245 40 18 all around. I would have liked to go wider, but I think that will be a little out of my budget. Maybe wider down the road. If the guy I'm buying the wheels from actually sends them to me (starting to look iffy) I'll have a wheelset for $550 including mounting & balancing.
Back to top |
rouseyss/sc member
Posted: Thu Mar 18, 2010 8:55 pm Post subject: |
man i couldnt imagine going through the problems with rust that youve had to deal with i would be pissed beyond belief.. glad to see you not giving up man
Back to top |
bprzybyl member
Back to top |
bprzybyl member
Posted: Mon Mar 22, 2010 10:59 pm Post subject: |
Well I hope someone is enjoying these pictures, if not oh well. Regardless, I was very productive this weekend.
Just in case anyone was wondering at this point
Vehicle: 1995 Nissan 240SX
Engine: 2005 Chevrolet Silverado 1500 5.3L V8 (L33)
Transmission: 2003 Chevrolet Avalanche 4L60E Automatic
Mount Kit: Otto's Version 1 mounts w/ 4L60E mount
Headers: Hinson Supercars Stainless Steel Headers
Motor found its way into the bay...
Sway Bar Clearance with a filthy quarter on the sway bar for size:
I really like this shot, it'd be quite a bit better if my bay was tidy
Fit was pretty great with the headers as well, just would have wished they'd be a little closer to the floor pan. Otherwise, there's about 3/16" between them and the frame rails on each side:
I was astounded by the amount of radiator - water pump clearance I have:
And finally:
Honestly I didn't think things would fit as well as they ended up fitting, but I have run into a bunch of new problems, all of which I think shouldn't be to hard to overcome.
Problem 1: Oil pan hits side of crossmember pocket. For this one, I thought this might be a big problem, but after moving the motor around, i think it just hadn't settled all the way down on the mounts. If this problem comes back up, I'm going to throw a piece of 1/8" or 1/4" aluminum under the passenger side (the picture shows the passenger side) mount which should slide the motor over enough.
Problem 2: Throttle body is hitting the hood. This problem is one of the bigger ones I have, but should be fixable one way or another. The top of the throttle body is hitting, and by trimming that little corner that sticks up I should be able to get the hood to close without hitting it. The intake elbow is REALLY close to being able to fit on there, but if I can't get the intake on I'm gonna try cutting the webbing on the hood.
Problem 3: Transmission hits the tunnel. Honestly this aggravated me a little. There was a ton of space all around the transmission. I was fully expecting to have to pull the motor out thinking I hadn't beat the tunnel nearly enough. This is the one spot the trans hits the tunnel. Other than that, somewhere around a 1/4" clearance everywhere else minimum. I bet I could shove my hand between the tunnel and the transmission on the sides of it. The picture shows what I believe is the servo hitting the passenger side of the tunnel.
Problem 4: Steering shaft hits the header. After seeing rh4motorsports build using custom mounts and hinson headers, I was worried I'd run into the same steering shaft - header interference, and it seems I have. I'm gonna try grinding the universal down where it's hitting and also dent the headers in the location a bit for some insurance.
Honestly, pretty optimistic at this point. The only thing that really pisses me off at this point is getting that damn driver side header in. It literally took me 2 hours to get it in. And I still need to get the damn thing out again to finish up the welding on a bunch of stuff. Gah! and I know it would be easier had I dropped the car on the subframe as I had planned, but honestly this isn't that bad and I wanted to touch the suspension as little as possible. Hopefully tomorrow I'll be able to get the motor back out before I go to work, and thursday night I'll get the bay all squared away with wire wheeling and a quick white paint job. Friday will return the engine to the bay, and I'll have a rolling LS1 swap. From there it's fuel system and wiring.
Back to top |
kirk member
           Posts: 953 Location: OKC
Posted: Tue Mar 23, 2010 8:37 am Post subject: |
You're making excellent progress man! Keep us updated when you fix your issues.
Those pictures will be a great help to people!
Back to top |
stirfry89 member
            Posts: 166 Location: Victoria, TX
Posted: Wed Mar 24, 2010 4:27 pm Post subject: Re: Daily Driver 5.3L/4L60E S14 Build |
bprzybyl wrote: |
...This was originally going to be a budget build... |
very common statement of v8 swap 240sx guys, lol
Back to top |
rh4motorsports member
              Posts: 1111 Location: Arlington, WA
Posted: Wed Mar 24, 2010 6:25 pm Post subject: |
Ah yeah that header issue is because Hinson drops the whole subframe with like 1" blocks so the steering shaft goes down that same 1" and clears. I heated mine with the torch and used a round draft pin and banged on it lol. I don't see any issues so far with mine. I just much rather not have the binding issue then the flow.
I also added a couple big washers under my mounts to get rid of the pan touching on one side. I shimmed both sides though. _________________
Back to top |
randall member
Posted: Wed Mar 24, 2010 10:18 pm Post subject: |
Here are a few pics of mine. You can see where i modified the knuckle some. This is with a 1" spacer, i tried to do this with out a spacer but finally gave in and made a spacer to get the clearance needed. It seemed like i would have had to get that extra room from the trans tunnel and i didnt have mush more it would go without splitting the tunnel. Looks like i need to do some cleaning. _________________
Back to top |
atutt member
            Posts: 155 Location: Barrie, Ontario, Canada
Back to top |
