silviav8forums.com Forum Index
Log in Register FAQ Memberlist Search silviav8forums.com Forum Index
VH45de s14 swap
Goto page 1, 2, 3, 4, 5, 6  Next
Post new topic   Reply to topic    silviav8forums.com Forum Index » Build Threads
View previous topic :: View next topic
Author Message
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:12 pm    Post subject: VH45de s14 swap Reply with quote
So yea names jerry from miami, florida
Heres the specs
VH45de q45 V8
300zx Twin turbo 5 speed
Been working on it for a few weeks
Heres the car
s14
18 by 10 265/30
18 by 11 295/30
Full suspension , and brembos
Tranny
Engine out
Side by side
Going in
Yes the hood closes
Making headers
Clearing the sterring shaft
Back to top
View user's profile Send private message
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:12 pm    Post subject: Reply with quote
Merge collectors
Driverside
GRound clearance
Pass side
Out of the car, equal length FTW!!!
Valve covers just powder coated Ferrari wrionkle red
Back to top
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:14 pm    Post subject: Reply with quote
Well to update, I have replaced the timing chain. Cleaned the engine thoroughly, and ready to drop it back in.
Back to top
gsracer
Lv2 Member
Lv2 Member
Finnally got all the fittings in , now i can put it back together
Back to top
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:16 pm    Post subject: Reply with quote
Heres the latest progress.
Custom making a few things, the tranny will be here next week, so I'm putting the motor back in the car to get the rest of the stuff ready.
Water pump block off plate for electric water pump
Motor on the hoist about to go in
My first attempt at welding aluminum, dont laugh... Seriously. For remote oil filter mount
Back view
12 lb chrome moly flywheel
-16 AN fittings for water lines, two in, two out
Here it is back in again after powder coating and cleaning
Back to top
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:17 pm    Post subject: Reply with quote
Since I'm still waiting for the tranny getting some other stuff buttoned up.
Oil catch can, still have to put in the breathers, ill just pick up some little k&n filters.
Had a friend tig up the fitting for the water pump block off.
Heres the Trust oil filter block, no oil cooler yet Sad*
Back to top
gsracer
Lv2 Member
Lv2 Member
now we're cooking with fire. special thanks to mazworx. They sell this now for anyone who wants it
Back to top
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:19 pm    Post subject: Reply with quote
Heres where im at.
Due to a gross miss calculation on my part, i put one of the primaries on the pass header thru the starter and that kind of side tracked me for a while. I cut it off and im just gonna re route it.
Back to top
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:20 pm    Post subject: Reply with quote
Anyway heres todays progress , put the tranny back together took 15 minutes total.
Good news is the mazworx tranny to chassis mount for the sr20 kit is a direct bolt on in my application which means that the drive shaft for the vg trans with sr20 will bolt on too, makes this ten time easier
Back to top
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:21 pm    Post subject: Reply with quote
Got the driveshaft on. Another Mazworx part.
Engine coming out again for the 24 billionth time
Since i made the headers with out a tranny attached to the motor i wanted to make sure it didnt crash the headers into something after it was installed so did the driverside today
My Mile and a half of steering column clearance
Clutch will be here tommorow and after this weekend motor should be in there permanatly.
Back to top
gsracer
Lv2 Member
Lv2 Member
PostPosted: Mon Jun 18, 2007 10:22 pm    Post subject: Reply with quote
Fixed the pass side header, now it doesnt hit the starter anymore and clears everything else.
Got the clutch in today,
Its a z1 motorsports single disc should be good till 500lb/tq.
It all lined up fine, z32 pilot bearing even fit into the vh crank perfect.
Now if it would stop raining id put this f*cker in.
Back to top
gsracer
Lv2 Member
Lv2 Member
Its been rainging all day for the 5th day in a row.
Just getting little odds and ends with the valve covers and the headers done.
Wrapped them today. Tie raps are just to hold them in place because i ran out of hose clamps, and safety wire. Now me nor my passengers will burn there feet by the floorboard.
Back to top
rh4motorsports
member
member
PostPosted: Tue Jun 19, 2007 12:04 am    Post subject: Reply with quote
wow. nice build man! that's awesome! i love the ferrari red, and the headers are sick, mad mad props for the home build! great to see other v8's than the ls1! thanx a billion for posting your build here! how's the shifter, does it come out about in the hole or does it take some cutting? anyway, sweet build and can't wait to see more!
_________________
Back to top
View user's profile Send private message Visit poster's website
Lordrandall
member
member
PostPosted: Tue Jun 19, 2007 2:51 am    Post subject: Reply with quote
That is a wide ass engine. Awesome pictures.
Smile
_________________
Future LSx swap S14 SE
Back to top
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
0100
Founder
Founder
PostPosted: Tue Jun 19, 2007 9:02 am    Post subject: Reply with quote
Wow Shocked Awesome job! I love the plumbing. Engine looks so clean.
Back to top
Display posts from previous:
Post new topic   Reply to topic    silviav8forums.com Forum Index » Build Threads All times are GMT - 4 Hours
Page 1 of 6
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You cannot attach files in this forum
You cannot download files in this forum
Powered by phpBB © 2001- 2004 phpBB Group
Theme created by phpBBStyles.com | Themes Database
