| View previous topic :: View next topic |
| Author |
Message |
Kelly member
  Posts: 94 Location: Colorado Springs, CO
Posted: Sun May 11, 2008 10:13 pm Post subject: my 408 cu in 240sx |
i wanted to first say this is an awesome forum, there is lot of good info here.
here is alittle about my car,
hope you like it.
basic run down:
1996 base 240sx
408 cu in LSx (lq9 block, eagle crank/rods, diamond pistons (11.5-1 C/R), ls6 oil pump, apr everything in the bottom end)
mild ported lq9 heads, springs, retainers, clips, pushrods
ls6 intake, fast fuel rails and 42lb injectors
dual intank walbros, hinson longtubes,
6 spd, spec stage3 clutch
nismo 2 way diff
5 lug swap, z32 brakes, nitto drag radials
the motor sits on custom mounts, parts from the s10 mounts were used, tranny mount is custom.
the shifter sits ~1/2in forward from the center of the oem hole
the body is pretty clean, but it needs alittle work to get it where i want it, but for the most part it is stock. (5% tint, oem lip, ssr rims)
here are a few pics:
car was tuned on 85 octane on friday night, and made 416 hp, 450 tq
i will be switching over to E-85 after a few tanks of 85 oct, so i should seen alittle more tq.
its tuned on HPtuners by www.serviontuning.com
the car ran 12.0 @ 120mph in KY, but i havent had it to the track here yet.
im toying with the idea of twin 60mm turbos, but i think ill run a 100-150 shot for the remainder of this year.
i see most people are drifting lsx 240s, but this will be a drag/street car, (i may try drifting alittle)
if anyone has any info on setting up a 240 as a drag car, or can direct me to a forum where there is 240 drag info, im all ears
getting custom plates that say "ONE CAM" on it
if you have any questions, feel free to ask
_________________ 96 240sx | 408 cu in LSx
Drag Radials | Nitrous
| Back to top |
MunsonAuto member
Posted: Sun May 11, 2008 10:51 pm Post subject: |
| got any vids of this beast?
| Back to top |
Tony member
   Posts: 398 Location: Korea
| Back to top |
Kelly member
| Back to top |
Libertysyclone member
  Posts: 182 Location: SL,UT
Posted: Mon May 12, 2008 1:10 pm Post subject: |
Here is the Info on GT live
http://www.utahnissans.com/forums/showthread.php?t=6019
You may want to check up with some suby guys on Nasioc as they usually come out for GT live.
I hope to be around there with my LS1
LS6 ported polished heads
Torquer 2 cam
Stock bottom end.
| Back to top |
ruth'lessdet member
Posted: Mon May 12, 2008 1:33 pm Post subject: |
didn't you just sell this car?? im confused??? or are you the person that bought it???? _________________
LS2 Powered S14-Sold!!, Whats next?!? |
| Back to top |
Kelly member
| Back to top |
Cheeks member
  Posts: 12 Location: Pittsburgh, PA
Posted: Mon May 12, 2008 2:24 pm Post subject: |
you can always check out drag240sx.com
Im building my car for drag as well, changed up the setup a little bit, iron block 370 with a s480 turbo. Should be running soon. Are you familiar with the lsx shootout every year in memphis? I know it may be a hike but I'll be down there and have been trying to get as many lsx powered 240s down there as I can
_________________ 90 240sx
turbo lsx automatic
| Back to top |
Kelly member
Posted: Mon May 12, 2008 3:23 pm Post subject: |
the link redirects me to http://www.turnofftheinterweb.com/
i know about the lsx shoot out, and since i drove the car back from memphis a few weeks ago, i know the drive.
depending on how work is, i might be able to make it out there. i doubt the car will be boosted this year though, ill probably build the twin setup over winter (which seems like forever in CO)
| Back to top |
ruth'lessdet member
| Back to top |
Tony member
Posted: Tue May 13, 2008 8:26 pm Post subject: |
| Kelly wrote: |
| Libertysyclone- ill check it out for sure |
That would be awesome if you could make GT Live with us. If you have any questions or whatever send me a PM or head to that link. I'm "Tony" on UtahNissans too.
| Back to top |
Lordrandall member
    Posts: 441 Location: Burbank, CA
| Back to top |
justanls1 member
  Posts: 1 Location: NPR, Florida
Posted: Wed May 14, 2008 4:18 pm Post subject: |
What size cam do you have.
Also do you know what the car weights?
| Back to top |
Kelly member
| Back to top |
Slip-n-slide member
Posted: Sun May 18, 2008 8:57 pm Post subject: |
| Awsome car!!
| Back to top |
